Changes to revision 38542:
Edit by Alex Bendoyro:
Deleted
Added
Unchanged
Changes to text
[* icon_caution] The following step will require soldering experience.
[* black] Once the logic board is visible, notice the gold strip that connects the logic board to the rest of the phone.
[* black] To disconnect the logic board from the gold strip, use the precision tweezers to remove the piece of black rubber where the gold strip is connected to the logic board.
[* black] Use the spudger to carefully lift up the small latch that holds the gold strip onto the logic board.
[* black] This is the tricky part. Use the desoldering wick and soldering iron to removeDesolder the little piecepart of the gold strip that is attached to the logic board by placing the desoldering wick on top of the point where the the gold strip meets the logic board, and then place the soldering iron on top of the desoldering wick in order to withdraw the solder from the connectionboard.
