Changes to revision 33699:
Edit by Andrew Bookholt:
In Patrol
Deleted
Added
Unchanged
Changes to text
[* black] Insert wisdom hereSince the AirPort/Bluetooth board is mounted inside the all-metal case of this machine, Apple added an antenna that is mounted on the frame for the optical drive opening. Pretty clever!
[* icon_note] This antenna is not found on the [link|http://www.ifixit.com/Guide/Device/MacBook_Unibody_Model_A1342|MacBook Unibody], probably because the case of that machine is plastic and blocks less of the RF transmission/reception through the case
