Changes to revision 32158:
Edit by Andrew Bookholt:
- Deleted
- Added
- Unchanged
Changes to text
| [* black] Join the lead leaving the resistor to the stripped end of the wire by twisting the two together. |
| [* icon_note] The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible. |
| [* black] Solder the wire to the resistor. |
| [* icon_caution] It is essential that enough solder flows through the wire to create a permanent bond between the two |
