Changes to revision 27450:
Edit by Andrew Bookholt:
- Deleted
- Added
- Unchanged
Changes to text
| [* red] Remove the four silver Phillips screws attaching the logic board to the outer case. |
| [* icon_caution] To remove the logic board, you must first de-solder the leads of both microphones from the logic board. When soldering on a circuit board, be sure not to heat up the connection excessively. |
| [* black] Use a pair of tweezers to gently pull each lead as you heat up the joint with the tip of a soldering iron. |
| [* black] Repeat this process to remove all four microphone leads. Their locations are shown in orange on the first picture. |
