Changes to revision 27449:
Edit by Andrew Bookholt:
- Deleted
- Added
- Unchanged
Changes to text
| [* red] Remove the four silver Phillips screws attaching the logic board to the outer case. [* icon_caution] To remove the logic board, you must first de-solder the leads of both microphones from the logic board. When soldering on a circuit board, be sure not to heat up the connection excessively. [* black] [* black] Repeat this process to remove all four microphone leads. |
