Changes to revision 60457:
Edit by wcmcdermott:
Deleted
Added
Unchanged
Changes to text
[* black] The upper circuit board is held in place by another Phillips screw.
[* black] After removing the screw, maneuver the upper board past the two plastic clips on either side holding it in place and lift it up from the phone body.
[* black] Volume Control switch: Slide up and set aside.
[* black] The large black-coated foil section is the data connection between the two main circuit boards.
