Changes to revision 15727:
Edit by Luke Soules:
Deleted
Added
Unchanged
Changes to text
[* standard] This isn't nearly as pretty as the front, but there's some things worth noting here.
[* black] There are four cables that connect the LCD to the iMac:
[* blackred] DisplayPort
[* blackorange] Temperature sensor
[* blackyellow] LED backlight
[* blackgreen] LED backlight sync
[* icon_note] The key thing to note is that there's no special shortcut from the LCD to the external Mini DisplayPort connector. The signal will need to go through the logic board, so you'll need to have your iMac powered on if you want to display from an external video source.
Changes to images
Image 1 (old version)
Image 1 (new version)
