Changes to revision 15457:
Edit by Andrew Bookholt:
Deleted
Added
Unchanged
Changes to text
[* standard] Use a spudger to separate the battery from the adhesive securing it to the outer case.
[* icon_note] The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
[* black] Use the flat end of a spudger to push the logic board assembly slightly out of the bottom of the Nano.
