Changes to revision 153628:
Edit by Miroslav Djuric:
Accepted by Miroslav Djuric
Deleted
Added
Unchanged
Changes to text
[* black] Nikon D600 Repairability Score: 2'''2 out of 1010''' (10 is easiest to repair)
[* green] The battery can be easily replaced by opening the compartment with your thumbnail.
[* green] The tripod mount comes off after removing four Phillips #00 screws.
[* red] The D600 has several wires that need to be desoldered in order to take it apart.
[* red] Close to 9,000 screws hold the device together.
[* red] The LCD is fused to the rear case, and cannot be swapped without replacing the entire back of the camera.
[* red] For absolute safety, you need to discharge the flash capacitor, otherwise you risk accidentally killing your camera.
