Changes to revision 153472:
Edit by Miroslav Djuric:
Accepted by Miroslav Djuric
Deleted
Added
Unchanged
Changes to text
[* black] Insert wisdom hereNikon D600 Repairability Score: 2 out of 10 (10 is easiest to repair)
[* green] The battery can be easily replaced by opening the compartment with your thumbnail.
[* green] The rear cover comes off with minimal unscrewing/desoldering (for this kind of device), allowing you to access the motherboard.
[* red] The D600 has several wires that need to be desoldered in order to take it apart.
[* red] Close to 9,000 screws hold the device together.
[* red] Components are very tightly packed, making it more difficult to disconnect and remove them.
[* red] For absolute safety, you need to discharge the flash capacitor, otherwise you risk accidentally killing your camera
