Help
Installing iMac Intel 21.5" EMC 2389 Display
Replace the LCD display on your iMac Intel 21.5" EMC 2389.
Use this guide to replace the LCD display.
Image #1 Image #2 Image #3
Step 1 — Display  ¶
  • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
Image #1
Step 2  ¶
  • Slightly lift the top edge of the display out of the outer case.
  • Do not lift it too much. There are several cables attaching the display to the logic board.
Image #1 Image #2
Step 3  ¶
  • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Image #1 Image #2
Step 4  ¶
  • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
  • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
Image #1 Image #2
Step 5  ¶
  • Grab the plastic pull tab secured to the display data cable lock and rotate it towards upwards.
  • Pull the display data cable straight out of its socket on the logic board.
  • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Image #1 Image #2
Step 6  ¶
  • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Image #1
Step 7  ¶
  • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
