Page Help
Kindle 2 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Our Kindle 2 shipped on Monday, February 23rd, a day early. Thanks to UPS Next Day Air, we have the reader in our hands Tuesday morning.
first image
Step 1 — Kindle 2 Teardown  ¶
  • It's here!
  • Thanks to the magic of E-Ink, the Kindle comes with setup instructions displayed on the screen itself. No plugging in is required.
  • We'll post updates on twitter about interesting things that we discover as we go.
first image
Step 2  ¶
  • What comes in the box:
    • A quick start guide, complete with embossed letters
    • An AC adapter
    • The Kindle 2
  • Conveniently, the AC adapter can be used with either a wall outlet or a USB port.
first image
Step 3  ¶
  • Size comparison: Definitely not as big as a 17" MacBook Pro Unibody.
  • The Kindle 2 weighs only 10.2 ounces. Per pound, that makes the Kindle 2 even more expensive than the $2,799 MacBook Pro 17" Unibody we took apart last week.
first image
Step 4  ¶
  • The back. Nothing special about it.
  • Note the speaker holes on the bottom. We briefly tried the Text-to-Speech feature and were very impressed by the Kindle 2's ability to read the text displayed on-screen. But the honeymoon was quickly over and we started tearing into it.
  • Hopefully the insides will be more exciting... We'll let you know as soon as we can!
first image
thumb image 1
thumb image 2
Step 5  ¶
  • Prying the back off...
  • Getting inside is easy once you know how. We used some plastic opening tools and a metal spudger, and finally managed to get in.
  • The matte-gray top cover comes off first.
  • There are two Phillips screws to remove before the Aluminum back can be removed entirely.
first image
Step 6  ¶
  • We're in!
  • It's still not very pretty; just more white plastic.
  • Twenty Phillips screws hold the white plastic paneling in place.
  • Interestingly, nothing was attached to the large white and brown connector near the top of the board.
first image
thumb image 1
thumb image 2
thumb image 3
Step 7  ¶
  • Remove two Phillips screws and the battery lifts out easily.
  • The battery is Model No. S11S01A. It's a 3.7 V, 1530 mAh lithium polymer battery. The battery weighs in at 31 grams, just over 10% of the Kindle's total weight.
  • The wireless card is also easily removable by removing two Phillips screws.
  • There are two antenna ports on the wireless card, but there was nothing connected to the AUX port in our Kindle.
first image
Step 8  ¶
  • After removing sixteen more screws, we've made it to the main PCB.
  • Everything exciting is still beneath silver EMI shields.
  • The Kindle was designed by Lab126, a secretive Amazon subsidiary based in Cupertino that designs consumer devices. Thus far, they have only released the Kindle 1 and 2.
first image
Step 9  ¶
  • Lifting the logic board and display assembly out of its plastic housing.
  • There is no protective covering over the display. The display seen from the outside is the actual E-Ink panel.
first image
thumb image 1
thumb image 2
thumb image 3
Step 10  ¶
  • Even with the battery completely removed, the screen displays a crystal clear image.
  • The display is held by a "window frame" of adhesive. Gentle prods and twists from all sides with a plastic opening tool separated the display.
  • Removing the display reveals a bunch of vias on the PCB. Nothing too terribly exciting.
first image
Step 11  ¶
  • The logic board after removing the silver EMI shields.
  • The majority of the larger chips are made by Freescale, Samsung and Epson.
  • On the center-left side of the board is an outline of a SIM card with empty headers. Amazon left a opening in the plastic framework revealing this region. Was this left in for development and debugging?
first image
Step 12  ¶
first image
Step 13  ¶
  • The main processor is in the upper left. The Freescale chip is labeled MCIMX31LVKN5C M91E CTAH0850V. It's a 532 MHz, ARM-11 90nm 14mm package.
  • To the right of the processor, the Samsung K4X1G323PC is a 32MB mobile DDR SDRAM chip. There another Samsung SDRAM chip in the lower right.
  • The large Samsung package in the lower left is the Kindle's main memory. It's a 2 GB moviNAND package, which includes both flash memory and the cotroller.
  • The co-branded Epson and E-Ink chip on the right is the display controller. It is a PFBGA package that supports "high speed screen updates (2048x1536 at 50Hz+)."
first image
Step 14  ¶
  • The complete disassembly of the Kindle 2.
  • It seems to be the type of device that people will not bother modding... Or will they? Only time will tell.
