Help
MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Cable Replacement
Replace the AirPort/Bluetooth cable in your MacBook Pro 15" Unibody Early 2011.
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
Image #1
Step 1 AirPort/Bluetooth Cable  ¶
  • Use the flat end of a spudger to lift the AirPort/Bluetooth connector out of its socket on the logic board.
Image #1
Step 2  ¶
  • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable on the AirPort/Bluetooth housing.
Image #1
Step 3  ¶
  • Use the flat end of a spudger to gently lift the AirPort/Bluetooth connector out of its socket on the AirPort/Bluetooth board.
  • Remove the cable from your MacBook.
