Help
Installing iPad 2 Wi-Fi EMC 2415 Logic Board
Replace the logic board in your iPad 2 Wi-Fi EMC 2415
Use this guide to replace a damaged logic board.
Sections
Image #1 Image #2 Image #3
Step 1 — Logic Board  ¶
  • Use a plastic opening tool to lift the display data cable lock upwards.
  • Pull the display data cable out of its socket.
  • Be careful not pull the connector upward as you disconnect it from its socket.
Image #1
Step 2  ¶
  • Remove the LCD assembly from the rear panel assembly.
Step 3  ¶
  • If present, use a plastic opening tool to help remove the piece of tape covering the end of the dock connector cable.
  • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
  • Peel the dock connector ribbon cable off the rear panel.
Image #1
Step 4  ¶
  • Pry the speaker cable connector straight up from its socket on the logic board.
  • Be careful to pry only the connector, not the socket on the logic board, or you may destroy the socket.
Image #1 Image #2
Step 5  ¶
  • Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket.
  • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
  • Peel the headphone jack and front camera cable off the rear case.
Image #1
Step 6  ¶
  • Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
Image #1 Image #2
Step 7  ¶
  • Use the edge of a plastic opening tool to flip up the retainer securing the control board cable connector to its socket on the logic board.
  • Pull the connector away from its socket on the logic board.
  • Do not lift the cable upward as you disconnect it.
Image #1 Image #2
Step 8  ¶
  • Remove the two 2.1 mm Phillips screws securing the logic board bracket to the rear case near the digitizer cable socket.
  • Remove the logic board bracket from the rear case.
Image #1
Step 9  ¶
  • Remove the remaining three 2.6 mm Phillips screws securing the logic board to the rear case.
Image #1
Step 10  ¶
  • Use the edge of a plastic opening tool to gently pry the logic board up from the adhesive securing it to the rear case.
Image #1
Step 11  ¶
  • Lift the logic board out from the rear case and tilt it slightly toward the battery.
  • Do not try to completely remove it just yet. There is still an antenna cable attached to it.
Image #1
Step 12  ¶
  • Use the edge of a plastic opening tool to pry the Wi-Fi antenna connector up from its socket on the logic board.
  • Remove the logic board from the iPad 2.
