Installing MacBook Core 2 Duo Fan
- Author: iRobot
- Difficulty: Moderate
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Tools (continued)
Relevant parts
Step 1 — Fan ¶
Use a spudger to disconnect the orange optical drive cable from the logic board.
Step 2 ¶
Use a spudger to disconnect the black fan connector from the logic board.
If you have a MacBook Core 2 Duo Santa Rosa/Penryn, the black fan connector resides in a different location.
Step 3 ¶
Deroute the fan cable from behind the tab on the left side of the fan.
Step 4 ¶
Peel up the silver foil tape between the fan and the optical drive.
Step 5 ¶
Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
Step 6 ¶
Remove the following 2 screws:
One 3 mm Phillips on the right side of the fan.
One 6 mm Phillips on the left side of the fan.
Step 7 ¶
Lift the fan and its attached mounting bracket up and out of the computer, being careful not to rip the black felt tape.
