Help
Installing MacBook Core 2 Duo AirPort Card
  • Author: iRobot
  • Difficulty: Moderate
Install an AirPort Extreme 802.11g card internally.
Image #1 Image #2
Step 1 — AirPort Card  ¶
  • Disconnect the three antenna cables from the Airport card on the left side of the computer. Gently pull an antenna cable straight up to remove it.
  • Notice the order of the antenna cables from left to right is black, blue, and gray.
  • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there are only two antenna cables on the Airport card.
Image #1
Step 2  ¶
  • Remove the following 2 screws from the Airport card:
    • One 3 mm Phillips from the left side.
    • One 8 mm Phillips from the right side.
Image #1
Step 3  ¶
  • Grasp the Airport card at its top and slide it toward the screen and out of the computer.
