Help
Starbucks Barista Ready Light Replacement
Student-Created Guide
An awesome student from our education program made this guide. It is not managed by iFixit staff.
Shows how to disassemble and replace the ready light.
  • Author: David
  • Difficulty: Moderate
The ready light is a simple LED that shows when the Barista has heated up to its needed temperature. This LED may burn out or its connectors may loosen.
Image #1
Step 1 Ready Light  ¶
  • Unscrew the 6 screws from the back panel.
  • Remove the back panel.
Image #1
Step 2  ¶
  • Locate the ready light.
  • Gently push the fixture against the Barista wall.
  • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
  • Disconnect the wire lead connectors.
  • Remove the ready light unit (fixture).
Image #1
Step 3  ¶
  • Replace the old LED with a new LED.
  • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
