Page Help
Installing MacBook Pro 15" Core 2 Duo Model A1211 Left Fan
  • Author: iRobot
  • Time required: 45 to 90 minutes
  • Difficulty: Difficult
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
Tools
first image
Step 1 — Left Fan  ¶
  • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
first image
Step 2  ¶
  • Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
first image
Step 3  ¶
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
first image
Step 4  ¶
  • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
first image
Step 5  ¶
  • Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
