Page Help
Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display
  • Author: iRobot
  • Difficulty: Difficult
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
first image
thumb image 1
thumb image 2
thumb image 3
Step 1 — Display  ¶
  • Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board.
  • For A1229 and A1212 models, disconnect the three antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
  • For the A1229, the order of the cables from left to right is: Black (left; towards the edge of the case) — Grey (middle) — Blue (right; towards the middle of the case.
  • For the A1261 model, disconnect the two antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
  • Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
first image
Step 2  ¶
  • Remove the ten silver T6 Torx screws securing the display (five on each side-take note that the inside screws on both sides are longer with a thinner head).
  • Don't forget to replace the hinge end caps when reinstalling the display assembly. The end caps are side specific, so be sure that the posts are facing towards the lower case.
first image
Step 3  ¶
  • Grasp the display assembly on both sides and lift it up and out of the computer.
