MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Optical Drive Replacement
Replace the optical drive in your MacBook Pro 17" Models A1151 A1212 A1229 and A1261.
- Author: iRobot
- Difficulty: Moderate
Upgrade or replace the SuperDrive.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Optical Drive 3 steps
- Optical Drive Replacement 4 steps
Tools
Step 1 — Optical Drive Replacement ¶
Remove the single Phillips screw securing the mounting bracket to the left side of the optical drive.
Step 2 ¶
Rotate the drive and disconnect the orange ribbon cable from the optical drive.
Step 3 ¶
Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
Step 4 ¶
Rotate the drive and remove the single Phillips screw securing the mounting bracket to the right side of the optical drive.
If you purchased an optical drive without mounting brackets, simply transfer the three silver metal brackets and orange ribbon cable to your new optical drive.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
