Installing PowerBook G3 Pismo Display
- Author: iRobot
- Difficulty: Moderate
Change out the entire display assembly, including the hinges and plastic casing.
Sections
- Keyboard 3 steps
- Heat Shield 2 steps
- Airport Card 2 steps
- PRAM Battery 2 steps
- Heat Sink 2 steps
- Processor 2 steps
- Modem 3 steps
- Hard Drive 3 steps
- Clutch Cover 2 steps
- Inverter 4 steps
- Display 4 steps
Files
Tools
Relevant Parts
Step 1 — Display ¶
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black Torx screws.
Step 2 ¶
Returning to the front, pull the black Airport antenna up from its recessed housing.
Step 3 ¶
Hold the display on both sides and pull directly up until its hinges are free of their mounts.
Step 4 ¶
Your laptop should look approximately like this.
