Installing Palm Treo 600 Battery
User-Contributed Guide
- Author: Clement Poisson
- Time required: 10 minutes
- Difficulty: Easy
Follow this guide if the battery is dysfunctional and you want to replace it.
Step 1 — Battery ¶
Using metal tweezers, unplug small white plug.
Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
Step 2 ¶
Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
The battery may be glued to the phone.
