iBook G4 14" 933 MHz-1.33 GHz Hard Drive Replacement
- Author: iRobot
- Difficulty: Difficult
You can install hard drives up to 9.5mm thick.
Sections
- Battery 2 steps
- Keyboard 7 steps
- Lower Case 12 steps
- Bottom Shield 2 steps
- DC-In Board 3 steps
- Upper Case 6 steps
- Top Shield 2 steps
- Hard Drive 3 steps
- Hard Drive Replacement 3 steps
Files
Step 1 — Hard Drive Replacement ¶
Remove the hard drive brackets from the left and right sides of the hard drive.
Step 2 ¶
Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
Step 3 ¶
Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
