Page Help
iBook G4 12" 800 MHz-1.2 GHz Hard Drive Replacement
Replace the hard drive in your 800 MHz - 1.2 GHz iBook G4 12".
  • Author: iRobot
  • Difficulty: Difficult
You can install hard drives up to 9.5mm thick.
Sections
Files
Tools
first image
Step 1 — Hard Drive Replacement  ¶
  • Remove the hard drive bracket from the left side of the hard drive.
first image
Step 2  ¶
  • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
first image
Step 3  ¶
  • Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
  • This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
