enTourage Pocket eDGe Battery Replacement
  1. enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 1 of 3 enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 2 of 3 enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 3 of 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: step 2, image 1 of 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: step 3, image 1 of 3 enTourage Pocket eDGe Battery Replacement: step 3, image 2 of 3 enTourage Pocket eDGe Battery Replacement: step 3, image 3 of 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: step 4, image 1 of 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: step 5, image 1 of 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
3 other people completed this guide.
Adrian Do
355 Reputation
3 Guides authored
One Comment
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,423
