Zune Flash 2nd Generation Communications Board Replacement
  1. Zune Flash 2nd Generation Communications Board Replacement, Back Cover: step 1, image 1 of 2 Zune Flash 2nd Generation Communications Board Replacement, Back Cover: step 1, image 2 of 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Communications Board Replacement: step 2, image 1 of 2 Zune Flash 2nd Generation Communications Board Replacement: step 2, image 2 of 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Communications Board Replacement: step 3, image 1 of 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Communications Board Replacement: step 4, image 1 of 3 Zune Flash 2nd Generation Communications Board Replacement: step 4, image 2 of 3 Zune Flash 2nd Generation Communications Board Replacement: step 4, image 3 of 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Communications Board Replacement: step 5, image 1 of 3 Zune Flash 2nd Generation Communications Board Replacement: step 5, image 2 of 3 Zune Flash 2nd Generation Communications Board Replacement: step 5, image 3 of 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
  6. Zune Flash 2nd Generation Communications Board Replacement, Communications Board: step 6, image 1 of 2 Zune Flash 2nd Generation Communications Board Replacement, Communications Board: step 6, image 2 of 2
    • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
  7. Zune Flash 2nd Generation Communications Board Replacement: step 7, image 1 of 2 Zune Flash 2nd Generation Communications Board Replacement: step 7, image 2 of 2
    • Use your finger to pry back the two clear flaps.
    • Slowly lift the communications board that was held down by the clear flaps.
    • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
  8. Zune Flash 2nd Generation Communications Board Replacement: step 8, image 1 of 1
    • Disconnect the ribbon cable with the Zune opening tool by flipping up the black plastic flap where the ribbon cable connects to the memory board.
    • Pull the ribbon cable out of the memory board.
  9. Zune Flash 2nd Generation Communications Board Replacement: step 9, image 1 of 1
    • Peal the slim ribbon cable off the communications board using your fingers.
    • This slim ribbon is attached using an adhesive, so it cannot be reattached without more adhesive.
  10. Zune Flash 2nd Generation Communications Board Replacement: step 10, image 1 of 2 Zune Flash 2nd Generation Communications Board Replacement: step 10, image 2 of 2
    • Pull the cable connector straight up using your fingers.
    • Communications board remains.
3 other people completed this guide.
ybahman
139 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 11
All Time: 3,514
