Zenithink ZTPAD ZT280 C91 Back Panel Replacement
  1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: step 2, image 1 of 3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: step 2, image 2 of 3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: step 2, image 3 of 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 161
