Zeki TB782B Display Replacement
  1. Zeki TB782B Display Replacement, Display: step 1, image 1 of 2 Zeki TB782B Display Replacement, Display: step 1, image 2 of 2
    • Using the plastic spudger, remove the back casing of the device (it will snap off).
  2. Zeki TB782B Display Replacement: step 2, image 1 of 3 Zeki TB782B Display Replacement: step 2, image 2 of 3 Zeki TB782B Display Replacement: step 2, image 3 of 3
    • Using a #000 1.5 mm Phillips screwdriver, remove the screws along the inside of the device(there is two screws under the motherboard, do not forget those).
  3. Zeki TB782B Display Replacement: step 3, image 1 of 1
    • At this point, you should be able to remove the display.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 54
