Introduction
The viewfinder assembly includes the button board, I/O ports, buttons, and viewfinder. Replace all of them in one fell swoop with a new viewfinder assembly.
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the following four screws securing the back cover of the camera housing:
two silver 8.5 mm screws,
two black 8.8 mm screws.
Peel back the Kapton tape covering the viewfinder assembly ribbon cable connector on the motherboard.
Use the tip of a spudger to flip up the retaining flap on the viewfinder assembly ribbon cable ZIF connector.
