ZTE Tempo Front Speaker Replacement
  1. ZTE Tempo Front Speaker Replacement, Battery: step 1, image 1 of 2 ZTE Tempo Front Speaker Replacement, Battery: step 1, image 2 of 2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Speaker Replacement: step 2, image 1 of 3 ZTE Tempo Front Speaker Replacement: step 2, image 2 of 3 ZTE Tempo Front Speaker Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Speaker Replacement, Front Speaker: step 3, image 1 of 3 ZTE Tempo Front Speaker Replacement, Front Speaker: step 3, image 2 of 3 ZTE Tempo Front Speaker Replacement, Front Speaker: step 3, image 3 of 3
    • Use a plastic opening tool to unplug the wires by pulling them to the side.
  4. ZTE Tempo Front Speaker Replacement: step 4, image 1 of 2 ZTE Tempo Front Speaker Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use metal tweezers to remove the front speaker.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 166
