ZTE Tempo Front Screen Assembly Replacement
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: step 1, image 1 of 2 ZTE Tempo Front Screen Assembly Replacement, Battery: step 1, image 2 of 2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: step 2, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement: step 2, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 3 of 3
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: step 5, image 1 of 2 ZTE Tempo Front Screen Assembly Replacement: step 5, image 2 of 2
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: step 6, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement: step 6, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 311
