ZTE Speed Earpiece Speaker Replacement
  1. ZTE Speed Earpiece Speaker Replacement, Motherboard: step 1, image 1 of 2 ZTE Speed Earpiece Speaker Replacement, Motherboard: step 1, image 2 of 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Earpiece Speaker Replacement: step 2, image 1 of 2 ZTE Speed Earpiece Speaker Replacement: step 2, image 2 of 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Earpiece Speaker Replacement: step 3, image 1 of 2 ZTE Speed Earpiece Speaker Replacement: step 3, image 2 of 2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Earpiece Speaker Replacement: step 4, image 1 of 1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Earpiece Speaker Replacement: step 5, image 1 of 3 ZTE Speed Earpiece Speaker Replacement: step 5, image 2 of 3 ZTE Speed Earpiece Speaker Replacement: step 5, image 3 of 3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Earpiece Speaker Replacement: step 6, image 1 of 2 ZTE Speed Earpiece Speaker Replacement: step 6, image 2 of 2
    • Carefully take off motherboard.
  7. ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 1 of 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 2 of 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 3 of 3
    • The earpiece speaker is located at the top-middle of the phone.
    • Using the plastic opening tool, carefully press into side of earpiece speaker and push up.
    • You will then be able to grab the speaker with your figers and remove it.
Garrett Barry
722 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 403
