ZTE Quest n817 Power/Volume Button Replacement
  1. ZTE Quest n817 Power/Volume Button Replacement, Battery: step 1, image 1 of 3 ZTE Quest n817 Power/Volume Button Replacement, Battery: step 1, image 2 of 3 ZTE Quest n817 Power/Volume Button Replacement, Battery: step 1, image 3 of 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Power/Volume Button Replacement: step 2, image 1 of 2 ZTE Quest n817 Power/Volume Button Replacement: step 2, image 2 of 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Power/Volume Button Replacement, Motherboard: step 3, image 1 of 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Power/Volume Button Replacement: step 4, image 1 of 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Power/Volume Button Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Power/Volume Button Replacement: step 6, image 1 of 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Power/Volume Button Replacement: step 7, image 1 of 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Power/Volume Button Replacement: step 8, image 1 of 2 ZTE Quest n817 Power/Volume Button Replacement: step 8, image 2 of 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  9. ZTE Quest n817 Power/Volume Button Replacement, Power/Volume Button: step 9, image 1 of 1
    • Each of these buttons can be removed using micro-soldering techniques around either side of the button.
    • Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
Eric Loureiro
582 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 276
