ZTE Quest n817 Daughterboard Replacement
  1. ZTE Quest n817 Daughterboard Replacement, Battery: step 1, image 1 of 3 ZTE Quest n817 Daughterboard Replacement, Battery: step 1, image 2 of 3 ZTE Quest n817 Daughterboard Replacement, Battery: step 1, image 3 of 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: step 2, image 1 of 2 ZTE Quest n817 Daughterboard Replacement: step 2, image 2 of 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: step 3, image 1 of 1
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: step 4, image 1 of 1
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: step 5, image 1 of 1
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: step 6, image 1 of 1
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Eric Loureiro
582 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 250
