ZTE Prestige 2 Back Panel Removal
  1. ZTE Prestige 2 Back Panel Removal, Battery: step 1, image 1 of 3 ZTE Prestige 2 Back Panel Removal, Battery: step 1, image 2 of 3 ZTE Prestige 2 Back Panel Removal, Battery: step 1, image 3 of 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Back Panel Removal: step 2, image 1 of 2 ZTE Prestige 2 Back Panel Removal: step 2, image 2 of 2
    • Remove the battery.
  3. ZTE Prestige 2 Back Panel Removal, Back Panel: step 3, image 1 of 3 ZTE Prestige 2 Back Panel Removal, Back Panel: step 3, image 2 of 3 ZTE Prestige 2 Back Panel Removal, Back Panel: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Back Panel Removal: step 4, image 1 of 3 ZTE Prestige 2 Back Panel Removal: step 4, image 2 of 3 ZTE Prestige 2 Back Panel Removal: step 4, image 3 of 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
Mackenzie Peterson
169 Reputation
2 Guides authored
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 121
