Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
Work your way around the phone with an opening pick to loosen the rest of the back cover.
Remove the cover.
Push in and then up on the bottom of the battery to free it from its compartment.
Pull the battery out.
Tool used on this step:Tweezers$4.99
Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
Remove the six 3 mm screws with a Phillips #00 screwdriver.
Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
