ZTE Lever Rear Camera Replacement
  1. ZTE Lever Rear Camera Replacement, Battery: step 1, image 1 of 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Rear Camera Replacement: step 2, image 1 of 2 ZTE Lever Rear Camera Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Rear Camera Replacement: step 3, image 1 of 2 ZTE Lever Rear Camera Replacement: step 3, image 2 of 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Rear Camera Replacement: step 4, image 1 of 2 ZTE Lever Rear Camera Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Rear Camera Replacement: step 5, image 1 of 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Rear Camera Replacement, Rear Camera: step 6, image 1 of 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Rear Camera Replacement: step 7, image 1 of 3 ZTE Lever Rear Camera Replacement: step 7, image 2 of 3 ZTE Lever Rear Camera Replacement: step 7, image 3 of 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Rear Camera Replacement: step 8, image 1 of 2 ZTE Lever Rear Camera Replacement: step 8, image 2 of 2
    • Using a plastic opening tool, disconnect the camera from the motherboard.
  9. ZTE Lever Rear Camera Replacement: step 9, image 1 of 1
    • Remove the camera from the phone.
Michael Gonzalez
501 Reputation
4 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 115
