ZTE Lever Charging Port Replacement
  1. ZTE Lever Charging Port Replacement, Battery: step 1, image 1 of 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Charging Port Replacement: step 2, image 1 of 2 ZTE Lever Charging Port Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Charging Port Replacement: step 3, image 1 of 2 ZTE Lever Charging Port Replacement: step 3, image 2 of 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Charging Port Replacement: step 4, image 1 of 2 ZTE Lever Charging Port Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Charging Port Replacement: step 5, image 1 of 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Charging Port Replacement, Volume Buttons: step 6, image 1 of 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Charging Port Replacement: step 7, image 1 of 3 ZTE Lever Charging Port Replacement: step 7, image 2 of 3 ZTE Lever Charging Port Replacement: step 7, image 3 of 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Charging Port Replacement: step 8, image 1 of 2 ZTE Lever Charging Port Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Charging Port Replacement: step 9, image 1 of 2 ZTE Lever Charging Port Replacement: step 9, image 2 of 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Charging Port Replacement, Power Button: step 10, image 1 of 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Charging Port Replacement: step 11, image 1 of 2 ZTE Lever Charging Port Replacement: step 11, image 2 of 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Charging Port Replacement, Motherboard: step 12, image 1 of 2 ZTE Lever Charging Port Replacement, Motherboard: step 12, image 2 of 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Charging Port Replacement: step 13, image 1 of 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Charging Port Replacement: step 14, image 1 of 2 ZTE Lever Charging Port Replacement: step 14, image 2 of 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Charging Port Replacement: step 15, image 1 of 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Charging Port Replacement: step 16, image 1 of 3 ZTE Lever Charging Port Replacement: step 16, image 2 of 3 ZTE Lever Charging Port Replacement: step 16, image 3 of 3
  17. ZTE Lever Charging Port Replacement: step 17, image 1 of 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Charging Port Replacement: step 18, image 1 of 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Charging Port Replacement: step 19, image 1 of 3 ZTE Lever Charging Port Replacement: step 19, image 2 of 3 ZTE Lever Charging Port Replacement: step 19, image 3 of 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Charging Port Replacement: step 20, image 1 of 1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Charging Port Replacement, Charging Port: step 21, image 1 of 1
  22. ZTE Lever Charging Port Replacement: step 22, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, separate the charging port from the motherboard.
    • Do not touch the metal as it may still be hot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 450
