ZTE Jasper LTE Speaker Replacement
  1. ZTE Jasper LTE Speaker Replacement, Battery: step 1, image 1 of 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Speaker Replacement: step 2, image 1 of 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Speaker Replacement, Camera: step 3, image 1 of 2 ZTE Jasper LTE Speaker Replacement, Camera: step 3, image 2 of 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Speaker Replacement: step 4, image 1 of 2 ZTE Jasper LTE Speaker Replacement: step 4, image 2 of 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Speaker Replacement: step 5, image 1 of 3 ZTE Jasper LTE Speaker Replacement: step 5, image 2 of 3 ZTE Jasper LTE Speaker Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Speaker Replacement, Speaker: step 6, image 1 of 2 ZTE Jasper LTE Speaker Replacement, Speaker: step 6, image 2 of 2
    Buy
    • Remove the speaker using the tweezers by gripping each side and pulling upwards.
    • Speaker is attached to the back case with adhesive. As such, you may need to use light force to remove the speaker.
Anthony Sou
391 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 10
All Time: 119
