ZTE Grand X Max Plus Camera Replacement
  1. ZTE Grand X Max Plus Camera Replacement, Back Cover: step 1, image 1 of 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Camera Replacement: step 2, image 1 of 2 ZTE Grand X Max Plus Camera Replacement: step 2, image 2 of 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Camera Replacement: step 3, image 1 of 2 ZTE Grand X Max Plus Camera Replacement: step 3, image 2 of 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Camera Replacement, Rear Camera: step 4, image 1 of 2 ZTE Grand X Max Plus Camera Replacement, Rear Camera: step 4, image 2 of 2
    • Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
  5. ZTE Grand X Max Plus Camera Replacement: step 5, image 1 of 3 ZTE Grand X Max Plus Camera Replacement: step 5, image 2 of 3 ZTE Grand X Max Plus Camera Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to remove the plastic piece that is protecting the motherboard.
  6. ZTE Grand X Max Plus Camera Replacement: step 6, image 1 of 1
    • With a plastic opening tool, unclip the camera from the motherboard.
  7. ZTE Grand X Max Plus Camera Replacement: step 7, image 1 of 3 ZTE Grand X Max Plus Camera Replacement: step 7, image 2 of 3 ZTE Grand X Max Plus Camera Replacement: step 7, image 3 of 3
    • After the camera is unclipped, remove it from the device.
Jordano Baer
689 Reputation
5 Guides authored
USF Tampa, Team S9-G4, Remmell Fall 2017 Member of USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 11
All Time: 170
