ZTE Grand X Max Plus Battery Replacement
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: step 1, image 1 of 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: step 2, image 1 of 2 ZTE Grand X Max Plus Battery Replacement: step 2, image 2 of 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: step 3, image 1 of 2 ZTE Grand X Max Plus Battery Replacement: step 3, image 2 of 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: step 4, image 1 of 2 ZTE Grand X Max Plus Battery Replacement, Battery: step 4, image 2 of 2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: step 5, image 1 of 3 ZTE Grand X Max Plus Battery Replacement: step 5, image 2 of 3 ZTE Grand X Max Plus Battery Replacement: step 5, image 3 of 3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: step 6, image 1 of 2 ZTE Grand X Max Plus Battery Replacement: step 6, image 2 of 2
    • Remove the battery.
3 other people completed this guide.
Jordano Baer
689 Reputation
5 Guides authored
USF Tampa, Team S9-G4, Remmell Fall 2017 Member of USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 2,996
