ZD-N Plus Wireless Controller Battery Replacement
  1. ZD-N Plus Wireless Controller Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Battery Replacement: step 2, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 2, image 2 of 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Battery Replacement, Battery: step 3, image 1 of 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Battery Replacement: step 4, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 4, image 2 of 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Battery Replacement: step 5, image 1 of 2 ZD-N Plus Wireless Controller Battery Replacement: step 5, image 2 of 2
    • Remove the battery from the controller.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 340
