Yamaha YZF-R6 Fan Relay Replacement
  1. Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: step 1, image 1 of 3 Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: step 1, image 2 of 3 Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: step 1, image 3 of 3
    • Use your motorcycle's key to open the rear seat, and remove the seat to access the tool pouch.
  2. Yamaha YZF-R6 Fan Relay Replacement: step 2, image 1 of 2 Yamaha YZF-R6 Fan Relay Replacement: step 2, image 2 of 2
    • Use a 10 mm Allen key to remove the front seat and expose the battery.
  3. Yamaha YZF-R6 Fan Relay Replacement: step 3, image 1 of 2 Yamaha YZF-R6 Fan Relay Replacement: step 3, image 2 of 2
    • Using a Phillips-head screwdriver, remove the screws attached to the battery terminals.
  4. Yamaha YZF-R6 Fan Relay Replacement: step 4, image 1 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 4, image 2 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 4, image 3 of 3
    • Using the 10mm Allen key, remove the hardware securing the left side fairings.
  5. Yamaha YZF-R6 Fan Relay Replacement: step 5, image 1 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 5, image 2 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 5, image 3 of 3
    • Remove the middle fairing on the left-hand side, and carefully unclip the turn signal cable.
  6. Yamaha YZF-R6 Fan Relay Replacement: step 6, image 1 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 6, image 2 of 3 Yamaha YZF-R6 Fan Relay Replacement: step 6, image 3 of 3
    • Once you have removed the left-hand cover under the clutch lever, locate the relay assemblies for the lights and cooling fans.
  7. Yamaha YZF-R6 Fan Relay Replacement: step 7, image 1 of 2 Yamaha YZF-R6 Fan Relay Replacement: step 7, image 2 of 2
    • Use a flat-head screwdriver to gently pry the locking mechanism open on the relay assembly. You can remove the relay by itself or with the bracket assembly.
Jose Perez 323
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 71
All Time: 218
