Yamaha FG-425 Guitar String Replacement
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 1 of 3 Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 2 of 3 Yamaha FG-425 Guitar String Replacement, Guitar String: step 1, image 3 of 3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: step 2, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 2, image 2 of 2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: step 3, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 3, image 2 of 2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: step 4, image 1 of 3 Yamaha FG-425 Guitar String Replacement: step 4, image 2 of 3 Yamaha FG-425 Guitar String Replacement: step 4, image 3 of 3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: step 5, image 1 of 2 Yamaha FG-425 Guitar String Replacement: step 5, image 2 of 2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: step 6, image 1 of 1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: step 7, image 1 of 1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Finish Line
Nicole Francheska Letigio
207 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 12
All Time: 244
