Yamaha APX-6N Guitar Strings Replacement
  1. Yamaha APX-6N Guitar Strings Replacement, Guitar strings: step 1, image 1 of 1
    • Loosen the guitar strings by turning the tuning pegs counter clockwise.
  2. Yamaha APX-6N Guitar Strings Replacement: step 2, image 1 of 1
    • To avoid injury, assure strings are loosened before cutting.
    • Once the strings are loose, cut them using the wire cutters.
    • After strings have been cut, remove them by pulling them out of the tuners and the bottom of the bridge.
  3. Yamaha APX-6N Guitar Strings Replacement: step 3, image 1 of 2 Yamaha APX-6N Guitar Strings Replacement: step 3, image 2 of 2
    • Insert the end of the string through the middle of the bridge until four inches comes through.
    • Wrap the short end of the string around the long end, making a loop.
    • Put the short end of the string through the loop around three to four times.
    • Pull both ends of the string until the knot is tight.
  4. Yamaha APX-6N Guitar Strings Replacement: step 4, image 1 of 2 Yamaha APX-6N Guitar Strings Replacement: step 4, image 2 of 2
    • Insert the end of the string into the hole on the correct tuning peg.
    • Pull the end over the tuning peg and loop under the string. Then push the end of the string under the loop.
    • Put the end of the string through the loop and pull both ends until the knot is tight.
  5. Yamaha APX-6N Guitar Strings Replacement: step 5, image 1 of 2 Yamaha APX-6N Guitar Strings Replacement: step 5, image 2 of 2
    • Repeat Step 4 for all other strings. Strings should be placed in the tuning pegs in clockwise order. Refer to string packaging for more details.
  6. Yamaha APX-6N Guitar Strings Replacement: step 6, image 1 of 1
    • Turn the tuning pegs clockwise to tighten each string until the string makes a sound when plucked.
    • Do not overtighten the strings! Strings may snap and lead to injury.
  7. Yamaha APX-6N Guitar Strings Replacement: step 7, image 1 of 1
    • After all strings have been replaced, tune the guitar to your desired tuning.
    • Check the headstock and the bridge for any loose string ends.
    • If necessary, use the wire cutters to snip off excess string.
    • The ends of the strings are very sharp.
You now have new strings for your guitar!
Benjamin
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 270
