X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement
  1. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Battery: step 1, image 1 of 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 2, image 1 of 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Underbody: step 3, image 1 of 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 4, image 1 of 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 5, image 1 of 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 5, image 2 of 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 6, image 1 of 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 7, image 1 of 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 8, image 1 of 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 8, image 2 of 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 9, image 1 of 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 9, image 2 of 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 10, image 1 of 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 11, image 1 of 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Rear Motor: step 12, image 1 of 1
    • Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
    • There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
  13. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 13, image 1 of 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 13, image 2 of 2
    • Remove all ten 1.6mm Phillips #000 screws from the rear motor casing
    • The first image shows five screws on the side with the circuitry
    • The second image shows five screws on the opposite side of the casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: step 14, image 1 of 1
    • Use a soldering gun to remove the attached wires
Trent Peterson
454 Reputation
3 Guides authored
Cal Poly, Team 24-3, Lancaster Spring 2015 Member of Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Members
9 Guides authored
One Comment
what size is the motor
mattsson97 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 510
