X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement
  1. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement, Battery: step 1, image 1 of 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement: step 2, image 1 of 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement, Headlight: step 3, image 1 of 2 X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement, Headlight: step 3, image 2 of 2
    • Unscrew the two 2.5 mm Phillips #00 screws from the underside of the car and remove the front underskirt.
  4. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement: step 4, image 1 of 1
    • Unscrew the four 2.5mm Phillips #00 screws from the front bumper and lift up the front bumper to remove.
  5. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement: step 5, image 1 of 1
    • Remove the front bumper by sliding it away from the car.
  6. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement: step 6, image 1 of 1
    • Remove the headlight cover.
  7. X-street Lamborghini Murcielago LP670-4 SV Headlight Replacement: step 7, image 1 of 1
    • Pull out the headlight.
    • Desolder and disconnect the headlight
Liam Martinez
562 Reputation
5 Guides authored
Cal Poly, Team 24-3, Lancaster Spring 2015 Member of Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 601
