X-Street STR Viper Wheel Replacement
  1. X-Street STR Viper Wheel Replacement, Wheel: step 1, image 1 of 2 X-Street STR Viper Wheel Replacement, Wheel: step 1, image 2 of 2
    • Remove the wheel. Begin by grabbing your metal spudger or a guitar pick to pop off the plastic cap in the middle of the wheel.
    • Use the #2 Phillips screwdriver to remove the 4mm Phillips #2 screw inside the wheel.
    • From here you should be able to easily pull off the wheel from the car and you're finished!
Ian Johnson
354 Reputation
2 Guides authored
Cal Poly, Team 12-6, Lancaster Spring 2015 Member of Cal Poly, Team 12-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 301
