World Dryer Airforce J4-973A3 Server Board Replacement
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: step 1, image 1 of 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: step 1, image 2 of 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: step 1, image 3 of 3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: step 2, image 1 of 2 World Dryer Airforce J4-973A3 Server Board Replacement: step 2, image 2 of 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: step 3, image 1 of 3 World Dryer Airforce J4-973A3 Server Board Replacement: step 3, image 2 of 3 World Dryer Airforce J4-973A3 Server Board Replacement: step 3, image 3 of 3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: step 4, image 1 of 3 World Dryer Airforce J4-973A3 Server Board Replacement: step 4, image 2 of 3 World Dryer Airforce J4-973A3 Server Board Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Blane Hirsh
260 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 259
