World Dryer Airforce J4-973A3 Sensor Board Replacement
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: step 1, image 1 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: step 1, image 2 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: step 1, image 3 of 3
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: step 2, image 1 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: step 2, image 2 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: step 2, image 3 of 3
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: step 3, image 1 of 2 World Dryer Airforce J4-973A3 Sensor Board Replacement: step 3, image 2 of 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: step 4, image 1 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: step 4, image 2 of 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: step 4, image 3 of 3
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: step 5, image 1 of 1
    • Carefully remove the sensor board from your device.
Luke Clancy
123 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 635
